geotex1
Jan 31, 2015Explorer
andrewwm wrote:
I also noted Wincrasher65 had problems setting up weight distribution with the air ride suspension, I have the autoride self levelling suspension. Will this cause problems.
It's no problem to set up. It just requires that you set it up at the scales instead of trying to do it via measurements. The measurement method is really only to get the initial setup in the ballpark before you head to the scales. My YukonXL 2500 has it too. Just remember to engage tow/haul when you set it up because it changes the autoride's behavior and you must also wait for the shocks to inflate and stabilize with each change in adjustment.
44,030 PostsLatest Activity: Jan 20, 2025
