UTCoyote
Feb 15, 2014Explorer
Anything better than plywood for floor?
Tackling a "soft spot" in the bathroom project...
I've got the bathroom floor all out. The sub floor was 1/2" plywood.
Is there a better/best type of sub floor material to use, other than simply replacing with the same plywood that was there before? As in, more moisture resistant and or stronger?
Figure as long as I'm doing it, and I only need one sheet of material, if there is something better to use, I may as well use it.
BTW... Pretty sure I've got the source of the leaks - from above and a plumbing leak hidden under the tub - fixed already.
Thank!
- Coyote
Thank!
- Coyote
