May-30-2014 07:54 AM
May-31-2014 01:07 PM
May-31-2014 05:31 AM
May-31-2014 05:23 AM
lawrosa wrote:
If i was to live in an RV fulltime it would be the nash line... Its a true 4 season RV IMO.. But you can get the same all seasons package in any of northwoods units.
http://www.northwoodmfg.com/index.php?page=makeplans&make=nashhttp://www.northwoodmfg.com/index.php?page=makeplans&make=nash
Made to live in..
Some of the standards...
10gallon water heater.
generator ready..( Yes on the towables.)
led lighting in and out.
off road chassis
20 watt solar standard
ducted a/c heat
3 30lbs propane bottles
Oven!!!
rear receiver for bike or cargo rack
15" radials tires
Make sure you look at the options...
The 24M is the perfect floor plan for 2 people...
http://www.northwoodmfg.com/index.php?page=model&make=nash&id=1097http://www.northwoodmfg.com/index.php?page=model&make=nash&id=1097
Here is the brochure...
http://www.northwoodmfg.com/images/rsync/brochures/Nash_Brochure.pdfhttp://www.northwoodmfg.com/images/rsync/brochures/Nash_Brochure.pdf
But of course if they are too small and you need bigger yes go with the fox..............
May-30-2014 09:21 PM
May-30-2014 09:09 PM
May-30-2014 08:30 PM
May-30-2014 01:57 PM
May-30-2014 10:20 AM
May-30-2014 10:08 AM
OP wrote:I would try harder to find housing.
for the past 5 years, there are several time periods of 7 days or more where the high temp doesn't reach 32 degrees and the low is below 25 degrees.
May-30-2014 08:58 AM
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
May-30-2014 08:35 AM
n7bsn wrote:
Define "cold"
No rig there is, as delivered, is up to sustained below zero use.
Your proposed "cold" would work, if you heated via propane (the heat ducts help keep the pipes/basement from freezing.
I believe (we did a lot of looking) that while Arctic Fox is -not- the best made rig in the world, it is the best value of the rigs we looked at. We had owned a Fox before, and when we started looking they were a solid "look for" on our list.
Their factory defects are low, due I believe Northwoods policy of basing worker bonuses on the amount of warranty repairs.
Their rigs are "tight", part of how they do this is pressure testing of the rig, before delivery to looks for leaks.
Due to pure chance, I was at the dealer when our current rig arrived. So I had the chance to see the rig as shipped.
There are those they say that you should only buy a rig from a firm that has lots of dealers nation wide, that sell the most rigs. This is the type of argument that says you should have bought from Fleetwood (before they went bankrupt) or GM (before they admitted to covering up recalls, and required a bail-out to keep from vanishing)
May-30-2014 08:09 AM
