49ford's avatar
49ford
Atwood furnace
I have a trailer with a Atwood 7920-II furnace. I have worked it down to the point it gives a code 3 for ignition lockout fault. Does anybody know what that means or what might be causing it? I am guessing it is an igniter problem.
It previously gave a code 1, which was limit switch or air flow problem. It turned out to be bugs inside the chamber I knocked loose by smacking the housing. Now the fan runs, but makes an low pitched click every so often then shuts off.
