Nov-13-2017 04:52 AM
Nov-15-2017 10:52 AM
Nov-15-2017 05:27 AM
Nov-14-2017 06:38 PM
Nov-14-2017 08:16 AM
budwich wrote:Traver8 wrote:
OP here with an update. Came back today after shutting the water heater off this morning and found it overheating again. I confirmed that it was indeed switched off and it was. Had to turn the breaker off to get it to stop heating. Double checked a couple of times but it does seem like the relay is stuck closed and providing constant 120v power to the element. Tried it a couple of times, breaker on and could hear the element heating. Can't get to it tonight but will pull the relay and check it but will be surprised if it is OK.
This is the second relay gone bad in 4.5 years of use so I may have to look for something that might work better. I don't know how to protect against something like this as switching off the water heater did not stop the heating.
Thought you all should know.
Terry
kind of late question but what model of atwood water heater do you actually have. Are there two switches (gas and electric) or just one?
Nov-14-2017 07:01 AM
Terry
Nov-13-2017 08:20 PM
Old-Biscuit wrote:
The Electric on/off switch and control circuit use 12V DC....hence the DC Relay that is used to trigger the 120V AC to element
So YES ....if the DC Relay is STUCK 'closed' the 120V AC is energizing the element even if the DC voltage is shut down.
TWO relays failing in 4.5 yrs is unusual....they are not a common fail point.
But does seem to be more issues recently with the DC Relay Component
Have seen two relays where the AC wiring as broken/separated from relay and NOT allow AC Voltage to element.
Must be some of that 'quality control' from component vendors :S
Simple $0.50 relay failing could make that water heater into a very dangerous heated vessel.
T-stat opens (140*F)......no shut down
ECO opens (180*F).........no shut down
T&P Relief Valve pops open (210*F)....hot water that flashes to steam blows out ---electric still energized/heating.
Water cools due to increased flow of cold water inlet so T&P closes only to pop back open and blow steam when water over heats
T&P Relief FAILS>>>>>>>>>>>. Pressure builds until something lets loose....fitting on water lines at WH Tank blowing steam inside RV
All Atwood combo units (electric/propane) since 2004 model/design change use the Combined DC control Circuit with DC Relay for electric side.
Replace that DC Relay ...then take some voltage measurements
Especially the AC Ripple.......using voltmeter set to AC Volts measure the DC Voltage. Anything AC Voltage on DC Circuits can cause issues/damages.
AC Ripple is from 'converter' capacitor failing.
Or just dumb luck with bad DC Relays
Nov-13-2017 06:43 PM
Nov-13-2017 05:43 PM
Nov-13-2017 10:37 AM
Nov-13-2017 06:23 AM
Nov-13-2017 05:51 AM
Nov-13-2017 05:43 AM
Nov-13-2017 05:13 AM
Nov-13-2017 05:07 AM
