Old-Biscuit
Oct 22, 2014Explorer III
First...
Were you using electric or gas?
Did red light on panel come on?
Does the gas burner come on at all?
IF burner comes on.....how long does it fire before turning off?
After it fires...pop open PRV (press relief valve) in outside compartment.
CAUTION: WATER SHOULD BE VERY HOT
*Check valve on backside of water heater tank in hot outlet line sticking close/plugged restricting hot water flow
*Bypass valve open---not fully closed on line that connects cold with hot on backside of water heater tank
*Showers not being turned off at cold/hot knobs just with button on handle will cause warm water due to mixing in shower faucet
Course that is IF water heater is turning on
