Atwood Water Heater Will Not Light
RAMBOY
The Atwood water heater in my 1 year old TT does not light. It worked fine last year. There is no clicking noise when I turn on the water heater power. It is a propane-only heater. There is propane in the lines since the furnace and oven both work. I checked the outside water heater fuses and both appear good (the small 2 amp fuse and the long fuse encased in a plastic tube). Any idea what I should check next?
5 REPLIES 5
bobndot
Check electrical connections.
If it still does not respond, it might be the circuit board. I had to swap mine for a new one on my one year old Atwood.
https://www.youtube.com/watch?v=u29Sl9j0TM4
dkeller
Are you getting propane to the heater if you are it could be the controller as I had same issue was covered under warranty.
2016 Ram 2500 4x4 6.7 Diesel
2018 Jayco T32C
Reese Straight-Line trunnion WDH
RAMBOY
SAR Tracker wrote:
Batteries charged? You'll need 12v to make the igniter work.
Yes. Also plugged into 30amp service.
Old-Biscuit
X2
Also hard to visually check fuses.
Remove the thermal cut out fuse and just wire directly to t-stat
(Brown wire to t-stat then from t-stat to circuit board)
Try lighting Water Heater.
OR
Use a voltmeter to test for DC Voltage
12V DC to On/Off Switch
12V DC from switch (BROWN) to 'thermal switch' to T-stat' to circuit board
12V DC from circuit board (RED) to ECO to gas valve solenoid
Solenoid (Black) to ground
SAR_Tracker
Rusty & Cheryl
2011 F250 2WD 6.2L Gasser
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
