Sport45 wrote:
JRscooby wrote:
I'm hard of understanding here. If you have a line from 1 tank down to another, the fuel will flow. And if the level of fuel is above the fill neck of the lower tank, or any vent, what will stop fuel from coming out the vent?
Mine has a float valve where it ties into the main tank fuel fill line. It doesn’t let any diesel in once the tank is full. I suppose it’s similar to the valve that stops water flow once your toilet tank is full.
I can see how that would work. OTOH, the valve in toilet starts to leak, water drains thru the overflow, overfills bowl, and down drain. Can waste a lot of water but that is the only harm unless you have to pay a plumber to replace it.
A similar system is the float/needle seat system in a carburetor. When that leaks gas can get on top of engine, but it also dumps into the engine stops it from running right (if at all). Fuel pump stops putting gas to carb. Fire is a possibility, but most likely expense is carb rebuild.
What happens if you park the truck with a leaking float valve.
BTW, in my lifetime I have replaced over 100 toilet tank valves, and rebuilt even more carburetors. Failure is not a far-fetched idea.
hotpepperkid wrote:
I want to hear the rest of the story.
In that area, most of the owners of small farms have some kind of job in town. We where on a main road into metro area, where the farmers likely to pass by commuting.
Most of the farmer have tanks set up, get fuel delivered for use in ag equipment. The sellers of that fuel do not collect the road taxes, so the fuel is cheaper. But to mark the fuel as non-taxed, the sellers are required to add dye to the fuel. A percentage of the farmers pump the dyed fuel in pickups. So on occasion the state tax collectors join the other LEOs and sample fuel as part of safety inspection.
As for my other infractions? MFIC told me to be right next trip thru. Rode home with other hands, used some chain and boomers to mount another transfer tank to a utility trailer, hauled it back and forth with my El Camino.
