djcjc
May 19, 2015Explorer
backup camera?
Is it possible to install a backup camera on the TT and hook it up to the existing display screen on the dash of a 2012 Ram 3500
brulaz wrote:
Nice. The original system allowing you to switch video feeds in the cab is definitely preferable to crawling under the tailgate.
But I have the same Ford in-mirror video display and would like to use it. Did you use the same after-market camera as in the first install for that? Did you just splice in a new RCA connector to the feed for the trailer?
2manytoyz wrote:
First, here's how I setup my previous tow vehicle with a backup camera, and how I added a backup camera to the travel trailer:
http://www.2manytoyz.com/backupcam.html
My F150 has a built-in backup camera and monitor built into the mirror. I didn't want to put an external monitor on top of the existing one.
A little research on the Ford forums and I found the wiring diagram for my specific vehicle. I tapped into the video camera feed lines going to the tailgate camera, and added an external video connector.
I use the OEM camera when hitching. Once coupled, I disconnect the tailgate camera, and plug the video feed cable from the TT to the new connector I added.
