ferndaleflyer wrote:
I have fixed 2 "bad Starters" in the past week. Both had dirty or loose battery terminals. Check them yourself.
In times past cleaning the battery terminals was part of routine maintenance, but now it is considered a repair. I wish I knew how certain we where the starter is bad. I don't know if Ford still uses the relay at the end of a short cable from battery. In times past, when I needed 1 more start to get to a shop, (Or on demolition derby cars) I would disconnect the cable from the starter side of that relay. Then a 2nd battery, hook (+) to that cable, and (-) to the relay terminal. When you turn the switch to 'start' that relay kicks in and the starter gets 24V most times it will crank.
Tal/IL wrote:
If you can get at the starter from underneath, rap on it few times with a mallet and it might start. If it does, don't shut it off 'til you get to the shop.
OT but gave me a laugh. A friend called me 1 night, he was out of town and his teenage kid was broke down at a party. He told her to tap on the starter. When I got there with another starter, the 1 I had to take off was beat so bad it could not even be a core. That little cutie had half the HS football team beating on that starter
