Bird Freak wrote:
JIMNLIN wrote:
Bird Freak wrote:
Know how your car bounces and vibrates when a tire is out of balance? Think your trailer is any different?
Much different for the same reasons that have been discussed before
How do you figure this? An out of balance tire will vibrate the vehicle period!
A tire can only show out of balance if its allowed to move up and down. Those short 26" long springs on a loaded trailer are a big damper vs a 70"-76" inch long spring on anther vehicle type with soft suspension .
Hell we ran lots of unbalanced tires on the rear on our older '60s/'70s trucks. Those old trucks had 35"-38" long springs with as much as 9 leafs in the pack. Those springs were also a excellent damper on out of balance vibration caused by tires. Now those soft front coil springs on those trucks had cause to be balanced.
A google on the subject has even more input on the reasons its not necessary to balance a tire on a trailer. Or a real experienced tire dealer is another source of that type of input.
As other have said the hub assy's aren't balanced and the short trailer springs still effectively dampen most if not all out of balance vibrations.
Before someone mentions were not talking about a utility/car hauler type trailer with no load.
