IdaD
Nov 27, 2018Explorer
Batteries - Diesel Trucks
I wanted to solicit a few opinions on batteries. My 2015 Ram is on it's original set of batteries, so about three and a half years of use and a little under 50,000 miles. I haven't had any failures to start yet but I've noticed a couple of times after running the grid heater on cold mornings the last week or two I've had a click before I turn the key back off and then it has fired up on the second try. I assume running the heater immediately prior to starting has run the batteries down enough they are tight on having enough juice for cranking the engine,
Am I at the point I need to replace the batteries? I'm a little on the early end of what I generally consider the replacement cycle for batteries in the other vehicles I've owned. I wondered with two batteries if I'd actually get a little extra life, but on the other hand it is cranking a bigger engine and running the grid heater.
Opinions?
Opinions?
