BBdawg's avatar
BBdawg
Battery operation question
I have 2ea 6volt batteries but when the 120ac power drops out, like a power failure, the 12 volt system does not automatically kick on. I must go out side and open and close the battery disconnect switch. As soon as I do this the 12DC power turns on and all is fine.
This seems to only occur when there is a temporary "power failure". Is this normal?
How would I check/verify the 12 volt charging is working from the converter?
Thanks for any input.
Randy
