ScottG
Feb 15, 2020Nomad
One little cheat we use for instances like this is to leave the tow vehicle hooked up so the trailer can run partially off your truck battery for the first night. This assumes the charge line stays hot when the truck isn't running (Dodge & GM = yes, Ford = no). It's unlikely you'll run it down appreciably and you could even run the truck while you shower and keep the battery charged.
44,029 PostsLatest Activity: Jan 27, 2025
