jawsthemeswimmi
Feb 17, 2020Explorer
opnspaces wrote:
Troubleshooting parasitic draw is usually in how you connect the test leads to the meter. For the amount of draw you are dealing with you can just run the trailer power right through the meter. Your meter should come with a basic instruction sheet for how to use the test functions. If not or if it's confusing, post us the make and model and we can help.
So when testing for parasitic draw, do I connect the multimeter to the battery? If there's parasitic draw how do you know which device it is coming from?
44,029 PostsLatest Activity: Jan 27, 2025
