Apr-22-2014 05:51 PM
Apr-29-2014 10:40 AM
Apr-27-2014 08:35 AM
Apr-27-2014 02:13 AM
dannytas wrote:
I may be a little slow...but do you pull your batteries because you store your trailer elsewhere? Is it inside or out? I'm only asking because I store my trailer at home and do use the Battery Tender Jr. as well and I don't pull the batteries.
To clear things up, I don't use the Battery Tender Jr. while the trailer is plugged into power and I don't use the because it's parked inside. 😄
Apr-26-2014 12:25 AM
Apr-24-2014 08:43 PM
Apr-24-2014 07:50 PM
Apr-24-2014 06:59 PM
Apr-23-2014 08:25 PM
Apr-23-2014 04:44 PM
Apr-23-2014 12:28 AM
Apr-22-2014 11:59 PM
falconman515 wrote:You could get close to the same longevity by just periodically charging (depending on overall use through the year).
Can I just throw my Schumacker charger on the batteries every month for a few and be fine?
Or is there an advantage to my batteries by having them maintained and fully charged at all times?
I keep them stored in the garage and the water is still full and fine after about a dozen discharges and charges last summer / fall.
I will be using them again come June / July ... maybe I will hold off and get a battery tender when they go back in storage again in the fall.
But is this really needed if I throw a quick charge on them every month???
Apr-22-2014 10:59 PM
Apr-22-2014 10:48 PM
smkettner wrote:
Battery Tender is an excellent brand. However 0.75 amp is a little light for 200+ amp hours of battery. For a few dollars more I recommend the waterproof 5 amp version.
Battery Tender 022-0157-1 Waterproof 12 Volt Power Tender Plus
OK maybe it is more than a few $$$ 😞
Apr-22-2014 08:16 PM
