Jan-03-2018 05:13 AM
Jan-03-2018 08:12 PM
Jan-03-2018 07:06 PM
Jan-03-2018 05:34 PM
Jan-03-2018 05:21 PM
DiskDoctr wrote:Not really because the back blast from a claymore mine will destroy the trailer. :E
Two purchases.
One new battery and one of these:
Warning: May require steam cleaning your camper in the Spring 😉
Jan-03-2018 03:59 PM
GordonThree wrote:
A disconnect between the bank and load makes sense. A disconnect between batteries, or multiple disconnects, I don't agree.
Jan-03-2018 01:04 PM
jerryjay11 wrote:
My question is should I replace the one they left behind and get two new batteries, or can I get away with just buying one, since the other one should have a few good years left?
As the Soundguy says. Batteries charging in parallel should be of the same strength or the weaker battery can drain the stronger battery when not charging. When charging the stronger battery will determine when the charging system will go into trickle charge and never bring the weaker battery up to full charge. Isolating the batteries as soundguy said would be a better option.
Jan-03-2018 01:03 PM
Jan-03-2018 12:32 PM
Jan-03-2018 12:13 PM
Jan-03-2018 10:56 AM
pianotuna wrote:Even better practice would be to not leave the batteries with the TT while in storage.
Best practice is to replace with two new jars.
Jan-03-2018 10:30 AM
Jan-03-2018 10:15 AM
GordonThree wrote:
X2, thumbs down for a switch / isolator, way too much complication.
Jan-03-2018 10:01 AM
Jan-03-2018 09:40 AM
Jan-03-2018 08:40 AM
