Roo Camper wrote:
I do have a couple questions though, ( and I'm sure more will arise along the way).. but firstly.. does anyone know of where I can get the reflective covers to put over the bed areas, to help keep the heat/cold out?
Secondly.. I have this nice flat screen TV..and no clue how/or what I need to do to be able to watch anything..
Thank you for your help..
Roo Camper
Most of us buy PUGs(popup gizmos).
the cheap and thin survival blankets are NOT the same and will not hold up.
you can buy the 5x7 sportsman/all-weather blankets that cost about $14 but one won't completely cover the longer front bunk.
they are available at Cabelas, REI and many other places.
As far as the tv, will you have cable hookups or not?
is the tv already hooked into coax outlet?
if you want use the tv antenna, that's a little more involved.
And remember, if you don't have electrical hookups, your outlets and tv will NOT work.
you have to have a generator for the outlets.
The tv can also work if you install an inverter.
