โAug-17-2022 01:44 PM
โAug-18-2022 01:29 PM
3 tons wrote:By any actual energy conversion you choose.
CA traveler said, โ5000 BTUs is equivalent to 1465Wโโฆ
By what method of calculation??
3 tons
โAug-18-2022 01:19 PM
โAug-18-2022 01:15 PM
JimK-NY wrote:adamis wrote:
I am surprised there are so many skeptics when it comes to running AC off of solar.
This is not a matter of opinion or wishful thinking just do the math.
โAug-18-2022 12:22 PM
This is not a matter of opinion or wishful thinking just do the math. Pick an A/C unit you think will work. Look at the specs for the wattage. That will probably be in the 700 watt range. That will mean each 100 AH of battery will last you a bit less than 2 hours. You also need to look at the amount of power you can expect from how every many solar panels you think you can fit on your roof. I would recommend using this calculator: http://www.where-rv-now.com/Notes/Solar/index.php
Remember that will be the absolute max you can obtain. I would not count on more than about half that output to compensate for other uses and for occasional clouds and shade. Do the calculations yourself to see if your plans make sense. Again this is not a matter of opinion.
โAug-18-2022 11:58 AM
3 tons
โAug-18-2022 11:23 AM
โAug-18-2022 11:11 AM
adamis wrote:
I am surprised there are so many skeptics when it comes to running AC off of solar. There are many people who already done this in some form already. 3 tons I know specifically is doing it and his setup is very impressive.
With the right setup, 400 to 600 watts of solar and 400AH of battery will get the job done. Now, you might run into issues if you are doing it over multiple days, the solar might struggle to keep up over time but that is when you can bring out the Honda generator and run it for a few hours to top the batteries back up.
In regards to a window AC unit, I think they could be a great option if I was to go the route of trying to combine the furnace and AC into one "box" that goes in the current furnace location. I would probably look for a 7500BTU unit and this is definitely a skilled fabrication job but I'm not seeing any technical reasons it couldn't be done.
Wouldn't a combined AC/Furnance that fits under one dinette seat and vents out the side by much more desirable than having a large bulky unit on the roof?
โAug-18-2022 10:30 AM
โAug-18-2022 10:13 AM
JimK-NY wrote:
So your 200 watt panel put out a peak of 118 watts and a total of 850 watt hours, not 850 watts. That would run a very small, 300 watt, A/C for almost 3 hours. It would run a more typical small unit for about 1 hour and a medium size RV A/C for about 45 minutes. To make up for inefficiencies, a bit of cloudiness or shade and the use of panels mounted flat on the roof and some other minimal electrical use, I would think maybe a 1000 watts of panels would be about right. You would also need a minimum of 1000 AH of batteries which is about a dozen car sized batteries.
โAug-18-2022 10:04 AM
โAug-18-2022 10:03 AM
โAug-18-2022 09:43 AM
โAug-18-2022 09:28 AM
โAug-18-2022 08:38 AM
JimK-NY wrote:jaycocreek wrote:
Yesterday my 200 watt solar panel I have hanging on the ladder rack waiting for installation parts put out 850 watts
This makes no sense. A 200 watt solar panel is rated to produce 200 watts at the maximum; i.e., full sun and directly overhead. Efficiency also drops off at higher temperatures such as on the roof of an RV. Of course roof mounted panels are going to be at a severe angle away from the sun for most of the day, depending on the length of daylight and latitude.
โAug-18-2022 08:29 AM
mkirsch wrote:Thanks for reminding me that efficiency values are involved in A/C ratings.CA Traveler wrote:jaycocreek wrote:5000 BTUs is equivalent to 1465W, so not sure your A/C size that only uses 330W. :h
My 5k window AC draws 330 watts with the compressor on and 59 watts with the fan on high..
Those are "marketing" BTUs. Same as your "3HP" household upright vacuum cleaner which runs off a common 15A 120V AC circuit.
