May-15-2022 07:46 AM
Aug-28-2022 02:26 AM
Aug-27-2022 05:19 PM
bigfootgrey wrote:
I’ve been contemplating installing rain gutters for awhile. Finally put Trim Loc over all the windows. The weather has been hot enough lately to soften the material to make it easier to work with and allow a good bond for the 3-m tape
Aug-25-2022 08:56 AM
Aug-16-2022 07:21 AM
JIMNLIN wrote:
My current 32' 5er didn't come with a drip channel or awning rail.
I ordered enough EZE RV Rain Gutter system for the roof edge and down the corners about a foot.
Its a stick on type. That was in 2000 and its still stuck tight and drains the water to the end corners and down. No sidewall streaks.
Aug-16-2022 05:25 AM
May-29-2022 03:14 PM
Grit dog wrote:
Curious, what do you use to strip it off?
May-29-2022 11:03 AM
May-29-2022 09:05 AM
May-23-2022 10:33 AM
JimK-NY wrote:TxGearhead wrote:
I have heard that it yellows and peels off in pieces. Difficult to completely remove. Your experience?
Mine has been on the RV for several years with no peeling, no flaking, no yellowing. I typical do a Spring cleanup with a soap and water and then apply another thin coat of Zep by wiping with a dampened rag.
A couple of years ago I did have an issue with bug splatters that had dried on for months. I had to strip the nose of the RV and apply several thin coats of Zep.
There is a major issue and that is surface prep. Zep is not going to do well when applied over dirt, old paste wax or on an old, oxidized surface. I used wax stripper, then swabbed again with a pretty stiff ammonia solution. Finally I hand scrubbed the entire RV with a 3M scotch pad and Bar Keepers Friend. That sounds like lots of work but really that was not much more than it would take to hand apply a paste wax finish. After prep, I used a rag dampened with Zep to apply thin coats. It takes a minimum of two coats to get a decent shine and a couple more to build up the finish so it will last. I can say for sure it does last, year after year.
Zep also stops oxidation and bleaching of surface due to sunshine. The acrylics in Zep block UV light.
May-23-2022 09:58 AM
May-21-2022 09:44 AM
May-16-2022 06:32 PM
May-16-2022 02:24 PM
May-16-2022 01:58 PM
Grit dog wrote:TxGearhead wrote:
I'll probably start with light polish and see what happens. I've got a collection of miracle cures that don't work.
There's no miracle cure, other than keeping water from running down the surface in the first place, IMO. Our new camper last year, takes up too much of the shop, so it is outside. Just from being parked on a cross slope, the one front gutter would drain onto the side of the camper. It would only take a few weeks and it would have a streak that required some elbow grease to remove. Started blocking up the low side wheels, no more water, no more streaks.
