AH_AK's avatar
AH_AK
Bigfoot (old vs new)
Does anyone know how the construction of Bigfoot TC’s has evolved over the years? Used BFs (pre 2009) are substantially lighter than the new models of the same dimensions. Based on the literature on 2000 BFs, it appears that the older versions relied on a combination of a thinner fiberglass shell and a sparse wood sub frame for their structural integrity. Also, the foam appears to be expanded-in-place (injected) on some models.
An article I found from 2019 describes the new construction as a standalone fiberglass shell with insulated panel facades on the interior. Given the weight of fiberglass, the overall increase in weight would make sense. The shell was likely thickened so it could bear the entire load without interior reinforcement. Am I wrong? If so, where is the additional weight coning from?
I can see the advantage of having the shell be standalone in terms of load bearing. Seems like even a bad leak/rot would not affect the structural integrity of the unit.
I am interested in hearing other general opinions about the new vs “old” Bigfoot design, materials, and construction techniques. Did they get better or worse after the reboot? For reference I am deciding on new vs used TCs for a 1t. SRW (4100 lb payload capacity). Weight is important, but I want to understand the tradeoffs, because you rarely get something for nothing.
