Acdii
Jun 17, 2016Explorer
Black tank question
I tried to search this, but not a clue to what I should even be searching for.
So when traveling, and you have a couple layovers before final destination, do you drain the tank at each start, or let it fill during the trip? Reason I ask is, you have to give waste some time to break down in a Septic system before it gets pushed out to the septic field. I believe it is much the same with the black tank as well, need to give the poo time to break down so it flushes out easier, or, you wind up with a clump. So say I am traveling two days to my destination, a stop over twice, drain the grey tank at each stop, but leave the black(provided it isn't more than half full) as is? I have the chemical stuff for the tank as well.
EDIT: No idea WHY the subject got garbled.
