toaobigal
May 17, 2014Explorer
Blower on my furnace keeps running.
I have a Atwood 8500 IV series furnace, this morning I started the furnace and I have heat. However, when it's warm enough, the blower runs for a little while longer than eventually stops: that's the part where I have the problem. The blower keeps running, I waited 1 hour and it won't stop. I had to turn the power/breaker switch on the blower to off. I don't think it's the thermostat because the heat works. I'm wondering if someone else had a similar problem. I tried removing the fuse that feeds the furnace, as soon as I put it back the blower is running, even if the switch on the thermostat is in the off position ( Dometic thermostat, with A/C) The A/C works ok. For now we're using an electric heater...
