Jun-01-2013 02:46 PM
Jun-03-2013 01:34 PM
Jun-03-2013 11:01 AM
Terryallan wrote:
Often, Especially on Dodge products. the doors will go the the defrost default position when you are towing, especially while pulling a hill. Why? Hard pulling causes low vacume pressure, and when the system loses vacume. It goes to the default Defrost position. It goes there, so IOF you lose all vacume. At least the defroster will work.
Jun-03-2013 11:00 AM
Jun-03-2013 06:05 AM
Jun-02-2013 11:18 PM
Jun-02-2013 06:35 PM
lamopar wrote:
I wish I had figured it out before tearing the dash all apart checking the recirculation door.
Jun-02-2013 06:34 PM
Jun-02-2013 06:13 PM
wnjj wrote:Greg B wrote:
If the blend doors are all working, maybe the a/c evaporator is freezing up. Maybe check the freon pressures?
This happened in my brother's S10 once in a trip in high humidity. It would slowly lose flow until there was almost none. Turning the heat on full blast would bring back the flow. Each time we stopped there was a huge puddle of water from the evaporator drain.
Jun-02-2013 05:35 PM
Jun-02-2013 11:12 AM
Jun-02-2013 10:04 AM
Jun-02-2013 08:41 AM
Jun-02-2013 07:54 AM
