Blowing heat into basement?
-Kevin
So I have looked the installs of the Camco heater and got so tired of my noisy furnace in my AF990 so I bought one. Question is how to get some of that heat into the basement...
I was thinking to wire the factory basement fan which is located under the bathroom step to a switch separate from the furnace, this way I can turn it on before I go to bed when I am using the Camco heater. Seems like a lot of power draw though...
any ideas?
2008 Dodge Ram 3500 QC DRW auto
2008 AF 990
FS bags
Viair OBA
Rancho 9000XL's
6 REPLIES 6
bighatnohorse
Like kerry, I installed an on/off switch to the fan.
But applying power to the fan made the furnace fan turn on.
So I put a diode inline with the power to the fan - that works, now I have manual control over the fan.
A guy on the club forum bought a used Arctic Fox and the basement fan comes on automatically when temperature drops below a certain point.
Apparently, the previous owner installed a thermostat in the basement with power to the fan - which is probably the best method by far.
2021 Arctic Fox 1150
'15 F350 6.7 diesel dually long bed
Eagle Cap Owners
“The best lack all conviction, while the worst
Are full of passionate intensity."
-Yeats
kerry4951
I installed a single pole 3 way switch to the basement fan. One position the fan comes on with the factory furnace, one position the fan can be turned off not to run at all, and one position the fan runs on its own. I can run my fan while using my baseboard heat or my Cat 3 heater. No need to run the furnace.
2009 Silverado 3500 dually D/A, Supersprings, Stable Loads, Bilsteins, Hellwig Sway Bar.
2010 Arctic Fox 1140 DB, 220 watts solar, custom 4 in 1 "U" shaped dinette/couch, baseboard and Cat 3 heat, 2nd dinette TV, cabover headboard storage, 67 TC mods
njtony
why not just use your furnace ?
-Kevin
awesome ideas guys. I will post install pics in the coming weeks.
2008 AF 990
FS bags
Viair OBA
Rancho 9000XL's
msiminoff
I built a small fan-in-a-box and installed it (along with a speed control) into the toe-kick area below my cabinetry... then ran a 2" duct from there into the basement. Works great...
Cheers,
-Mark
'04 Alpenlite Saratoga 935, 328W of solar, 300Ah Odyssey batt's, Trimetric, Prosine 2.0
05 Ram3500, Cummins,Vision 19.5 w/M729F's, Dynatrac Hubs, RR airbags w/ping tanks, Superhitch, Roadmaster Swaybar, Rancho RS9000XL
The Overlhander Blog
Glacier_D
Eagle Cap put in a 12 volt switched fan for me. Uses very little power, is quiet and really helps keep my basement at reasonable temps when the outside temps are in the teens or lower.
2011 Dodge Ram 3500 4X4 Crew Cab/LB, Rancho RS9000XL, Stable Loads, Superhitch and FastGuns. 2009 Eagle Cap 1050, Hickory interior with on-board generator, A/C and Honda EU2000
