Road_Phantom's avatar
Road_Phantom
Blue Ox 10000
I bought this hitch and lost one of the L shaped retainers that holds the equalizer bars in place. Is there anything besides the original piece that could work? I Can't find a replacement for it at the stores.
  • BarneyS wrote:
    I think this is the item he is talking about.:)
    Barney
    That's even easier. They aren't under any significant stress, so if they don't have them in stock, you could just get a piece of steel rod and bend it into an "L" and then drill a hold for the pin.
  • Did you contact Blue Ox?
    Etrailer seems to have them in stock:
    https://www.etrailer.com/dept-pg-Accessories_and_Parts-sf-Weight_Distribution_Hitch-pt-L~Bracket_Plates.aspx
    Worst case a good machine shop should be able to fabricate one without a lot of difficulty...probably won't be as cheap though.
