Bomberb52's avatar
Bomberb52
Bonding method
Looking to see if anyone knows if Keystone Sprinter campfire models have vacuum bonded walls or not. Literature on the model is very vague. It just says bonded. Thanks
  • If the literature doesn't say vacuum bonded, then it is likely that one or more production facilities is using presses and faster setting adhesives. High volume plants tend to use presses because volume is enough to cover the greater capital investment. Using vacuum bags requires less investment but more labor, and longer production cycles because of need to use slower setting adhesives and the additional time to bag and unbag each panel.
