transamz9
Apr 05, 2016Explorer
06Fargo wrote:alboy wrote:
I would not touch air bag susp unless you had auto load levelling capability.
Agree with ^.
Also - my air suspension uses hydraulic shocks not gas charged shocks... so maybe try a pair of hydraulic shocks first - you might find your pogo stick "bounce" is gone once you run shocks that dampen the springs in both directions...
Why would you not buy air springs without auto level. I don't have auto level and I have far more adjustments and versatility. I can do things only people could dream about with my suspension.
I should have done a little more homework when I bought my 5100's. The main reason I went with them is because they are designed with different heights in mind. I run my suspension at different heights depending on what I'm doing. I also had planned to bag the front of my truck also so there was the possibility of running at different ride heights completely.
44,029 PostsLatest Activity: Jan 13, 2025
