wgriswold's avatar
wgriswold
Brake rewiring
While taking my trailer to storage I got three messages:
"Check trailer wiring"
"Check trailer brake wiring"
"Trailer brakes disconnected"
The brakes were periodically disconnected which I confirmed with the manual brake function.
I have replaced the 7 pin cord and the next step is to replace the trailer brake wiring. I can do this job and my experience with boating electrical systems causes me to much prefer crimped connections. I am planning on running 12 gauge double wires down each side.
My problem is that I can't figure out how to connect two wires into one with a crimp. I need to do that at both ends of the new wire. There are Y connectors that would work but I would prefer a connection that would be entirely under heat shrink tubing. Is there a better solution?
As always, thanks for your help.
