Broken Frame on a RAM 3500
deltabravo
You may have seen pics of this truck and camper floating around the interwbez for the last few weeks.
Here's an article about it that was published earlier today.
103 REPLIES 103
jimh406
mkirsch wrote:
Eh, no. I've tried pointing out parameters and telling people to decide for themselves, only to get beat down by the "The numbers are meaningless, just haul whatever you want! It's a DUALLY!" crowd. So much so that I've pretty much joined them.
I agree that some people think DRWs are invincible. Personally, I pointed out that there are probably just as many DRWs that are over GVWR as SRWs, or for that matter, all RVs.
I know many Class A owners never even think about being overloaded or checking their tire pressure. Amazing what you can learn talking to other RVers at campgrounds. ๐Ÿ˜„
notsobigjoe
Nomad III
Nomad III
Bedlam wrote:
Some of the camper weight ratings I have seen assume a 150 lb person in every seat. If you have six seating, that reduces your camper carrying rating by 900 lbs.
Chevy does it this way. I have a dually crew cab with 3 seats front and back, that's 900 pounds. This is probably the best thread I've read and participated In on this forum. The weight police pros and cons be darned, truck camping takes some thought to be realistically safe on and off the road. As we all see the price is really something. JMHO
Grit_dog
Navigator
Navigator
mkirsch wrote:
I find this whole thread hilarious. This forum has been dedicated to beating down "weight police" for years... "You don't need to worry about weight! GVWR is meaningless! It's a DUALLY! The AAM axle is rated for 11,000lbs! Just add up your tire capacities, slap in a set of airbags, and GO! If the tires don't add up to enough, get 19.5's! Nobody that's anybody pays attention to weight! It'll be fine!"
Now all of a sudden everybody's a weight police. "Oh he was 10lbs over GVWR! That's why his frame broke!"
Lol, youโ€™re kinda right! Although to be fair Iโ€™ve generally been in the camp of srw trucks chassis can handle about what duallies can save for tires wheels and springs. Therefore they are under rated and no issue overloading to an extent. But if 1 ton Dooleys were under rated the same then theyโ€™d look like their class 4 and 5 cousins and those trucks wouldnโ€™t have the much stouter chassis that they do have.
But in this guys case he was waaaay over the 14k gvw number which is still a very safe number for that truck. And he likely wasnโ€™t over the real axle or tire/wheel rating. No flat tires and bent axles in that pic. Just a tacoโ€™d frame. Which even someone like him got 25k miles out ofโ€ฆ..
Heโ€™s the reason that ratings exist, because not enough working material between the ears to know when he was pressing his luck.
That setup was likely around a full ton over the gvwr. Or 2 tons over a srw or 3 tons over a srw 2500. All with the same basic chassis.
See now why Iโ€™m not worried about 4000lbs in the back of a 2500 hurting the truck itself?
Grit_dog
Navigator
Navigator
Groover wrote:
Grit dog wrote:
Another good point. No one knows how his rear suspension was set up. But one thing is certain, that camper wonโ€™t haul on that truck without something else besides the stock springs.
Unless you are bottoming out the suspension going with stiffer springs adds stress to the frame. The suspension is there to absorb the bumps. Making it stiffer reduces that capability.
Agreed for the most part. And bottoming out stresses the frame right over the rear axle. Been there done that got the T shirt! (To be fair Iโ€™m the guy that welded the frame back together when I was in high school, I would have been smart enough to not put a 7klb skid steer along with a spade attachment in an approximately 2000lb dump bed with a 20klb tag trailer loaded sitting on the factory 2โ€ receiver!). Even before I knew as much about vehicles I could do basic math and my eye sight was pretty good! Lol
However excessive cycling of the suspension also puts stress on components. Typically minor elastic deflections that after xxx,xxx number of cycles work hardens steel and leads to brittle fractures. (At least thatโ€™s what I learned in mechanics of materials and metallurgy courses after I saw it happen in the real world).
Grit_dog
Navigator
Navigator
Good to see ya Kayteg!!
Kayteg1
I don't know if I will be back to this forum, but for years I've been pointing how important is COG in TC combo. Lot of members downplayed the issue.
So in case of this Dodge the frame could bend this way only when COG was way behind rear axle.
Would COG be properly adjusted on top, or in front of axle, the rear bending forces would not exist.
Kayteg1
I no longer own TC and come here just because of those articles.
The pictures of similar broken Ford have been cruising this forum for years, but the limited information we had about Ford incident lead to believe that the owner welded tie-downs to the frame, what weakened it and then very heavy trailer on stinger did not help.
This Dodge incident is another story as the truck did not have any modifications and broke plain under camper weight.
Just for the record, I drove my 2017 F350 with 12' Fleetwood basement camper and coming back from Alaska, with collection of rocks and beer, the scales measured camper at close to 9000 lb.
Ford took it just fine, but my model was SuperCab and RWD with diesel.
Also for the record, the aluminum body dually Ford did not require any suspension reinforcement for the weight. I put Sulastic hangers for comfort and that was it.
Just saying
Fisherman
Maybe next time the owners will pay attention to numbers and not make hap hazard guesses.
JimK-NY
Did you notice the post from someone with the same truck? CCC is 4738#. The owner of the broken truck had a camper with a base weight of 5000#. Water and propane bring that to 5500#. Accessories are not included. We can see solar, awnings and a roof rack. I can't see if there is an A/C unit or a generator neither are in the base weight. At a minimum the weight will be 6000#. That does not include the bikes or rack, tools, kitchen gear, food, bedding, air compressor and personal items very likely totally well over 1000#. Best guess is this unit was in the range of 7000-7500# or roughly 2500-3000# over the CCC. In addition there is clearly an issue with center of gravity.
Sadly beginners and often experienced truck camper users often fail to realize how heavy their rigs are.
mkirsch
Nomad II
Nomad II
jimh406 wrote:
Of course, it's been more even than that. The weight police have had their say for at least 17 years. That's as far as I go back here. ๐Ÿ˜‰
People have been pointing out what the parameters are. Each person gets to decide what they do next.
An even better twist to this little soap opera is that this guy was DENIED WARRANTY!!! Thought that "never happened" guys. "How are they ever going to know?" Right?
jimh406
mkirsch
Nomad II
Nomad II
joerg68
Nomad III
Nomad III
If only a device existed with which you could find out your actual vehicle and axle weights... oh, wait...
When you are running a TC on your truck it is always a good idea to have the rig weighed. Most of the stated weights are optimistic and disregard certain details. And you can make optimistic weight assumptions and calculations about your rig all you want. None of that will alter physics.
Surely the numbers on the door sticker are no hard limits. But they are there for a reason.
2014 Ford F350 XLT 6.2 SCLB + 2017 Northstar Arrow
Groover
Grit_dog
Navigator
Navigator
