ricelake922's avatar
ricelake922
Still broken
Hello. I have a 1996 Monaco Dynasty. In previous post I wrote that I had seen three states to Florida by tow truck. The same problem occurs which is the 4D batteries lose power after 2 days. I can keep the RV running by charging the 4D batteries each night but that may not always be possible. First fix king cruise rebuild...RV broke down. The alternator has been changed three times. First time it was determined by mechanic that the 140 alternator and battery isolator s/b changed to a 200 amp. RV broke down again. I am now at Alliance in Wildwood Florida now. IThey thought they had fixed the problem by a loose wire and determining that new alternator was faulty as it was at 7amp. So new alternator. I kept telling everyone along the way that their solution was not right. So this morning brought up the jacks although back left jack had to be assisted by crane (need to get new back jack with springs) and RV would not start. 4D batteries were showing a low load and battery gauge was showing 10 amps. This is the same problem that the RV has had all along whereby the 4D batteries run so low that they have no power to go forward. Now at 3:00 I try to turn on the engine and it starts right up with battery guage showing14. I checked 4D batteries and the load and charge is fine.I am staying at Alliance still waiting for Monday to start again. Anyone had any solutions?
