Ed_95682
Apr 28, 2016Explorer
Bubbles in antifreeze flush
I've emptied my radiator antifreeze and used Fleetguard Restore following directions. I have a '99 ISC 8.3L Cummins diesel. After using the Restore product, I've flushed the system 6 times and on every occasion, it's like I've poured detergent soap into each container. It bubbles up and takes some time for it to dissolve.
I've been in contact with Cummins Filtration and they are perplex. After the 4th rinse, they thought it should certainly be clear.
The coolant filter is a new blank-no chemicals (WF2077) and I'm using Distilled water for my rinse/flush. I'm currently doing the 7th rinse/flush, but the bubbles (I've taken pictures, but can't attach) are just there. Can't get rid of them and was wondering if anyone else has experienced this situation.
Cummins, just says 'keep on rinsing/flushing'. I should also note, that I am doing the rinse as directed...i.e., new water, heater on high, running engine for 40+ min. after reaching operating temp (180), rpm 1500.
Any suggestions, ideas? Thanks,
