โFeb-20-2014 07:21 PM
โMar-03-2014 02:00 PM
45Ricochet wrote:wintersun wrote:
For towing the GM and Ford have been the best in terms of exhaust brake performance (corrected with 2013 and later Ram trucks) and transmission durability. So tell me exactly when Ford and GM offered a exhaust brake? Ram offered it in 2006, a Jacobs, who also offered it in OTR rigs although a totally different concept. Ford EB has been a joke and that is why they are changing it in 2015, finally.
I have used both Consumer Reports Now that there explains everything about your opinion. Ask the washer and toaster expert's their opinions. which does an annual survey of 100% of their members vehicles and industry repair shop numbers to evaluate different year and model trucks.
Engines are also only a piece of the equation. If the cooling system or AC or electricals or brakes or transmission are not reliable it also costs for the repairs and may entail a breakdown while towing which is the last thing you want.
Buy a diesel for the greater torque and the exhaust brake capability but don't but one for greater reliability. Pretty sure the Cummin's guy's will disagree with that statement. We have several member's still pulling strong with over 250K miles on the ticker. And don't compare the engines used in semi's to those put in pickups. Even the Cummins engines used in pickups are very different. Not really other than size, still a little slant six!
โFeb-26-2014 11:27 PM
45Ricochet wrote:bovellois wrote:rhagfo wrote:
Ram the Cummins 5.9 is one of the most reliable diesels in a HD pickup. the early 12 valve had a issue with the Killer dowel pin, I would place a bet most have been fixed.
I wonder what percentage of 12v Cummins engines had the pin actually move out. I have not done mine and the vehicle has 200000 miles. Either is has fallen and done no damage, or it's in there solid, or it has started to move out. I am looking at opening it it to see what's what. I know somebody who just dealt last fall with a fallen dowel pin. Not a cheap repair.
Lots just dropped them, lots didn't :E
If I owned one I'd be checking since my luck isn't that great :R
โFeb-26-2014 08:46 PM
gkainz wrote:
I pinned mine at about 160k miles ... it had moved out maybe 1/16" in.
โFeb-25-2014 12:01 PM
โFeb-24-2014 09:34 PM
โFeb-24-2014 03:19 PM
Redsky wrote:
It is easy to spend anywhere from $4,000 to $8,000 on a single diesel repair job. For a travel trailer a truck with a gas engine and 4.10 gears are all that is needed. It will be cheaper to buy and cheaper to maintain and cheaper to repair and cheaper to fuel.
Check the Ford, RAM, and Chevy diesel forums to get an idea of the problems that can arise and the cost of the repairs. Talk to people at the local diesel repair shop about a head gasket repair or replacing the fuel rails or a compressor.
Any used heavy duty truck is quite likely to also need front end work with new tie-rods and ball joints before you take it out on the highway. They are supposed to get greased every 3,000 miles but doubt that one in ten get it.
Lots to go wrong with diesel pickups besides the "engine" and gas engines are a lot more reliable as they are a lot less complicated (no compressor or high pressure fuel system or exhaust brake).
Check around town and see what percentage of the gas stations pump diesel. I have to drive 20 miles round trip from my house to get to one that pumps diesel. With gas the distance would be 3 miles and I would have 3 stations from which to choose.
โFeb-24-2014 03:02 PM
โFeb-24-2014 08:30 AM
โFeb-23-2014 05:57 PM
โFeb-23-2014 12:02 PM
ricatic wrote:Turtle n Peeps wrote:wintersun wrote:
All the diesel trucks had problems up until 2010 and the repairs are in the thousands of dollars. Getting a 2010 or later model year will be the safest way to go. An extended warranty is not a bad idea either with a diesel powered pickup truck.
There have been real world testing done by etrailer.com and by Road and Track (April 2012) that provide a good idea of the strengths and weaknesses of the different manufacturer's truck.
Lots of people will invariably state that they have X truck and it has been great but that is one person in a million trucks sold so their opinion is not reliable. I have used both Consumer Reports which does an annual survey of 100% of their members vehicles and industry repair shop numbers to evaluate different year and model trucks.
Buy a diesel for the greater torque and the exhaust brake capability but don't but one for greater reliability. And don't compare the engines used in semi's to those put in pickups. Even the Cummins engines used in pickups are very different.
I don't think I have seen such misinformation in one post in a long time. :R Troy this guy is trying to take your title away from you. You need to step up your game. :B
:B:B:B:B:B...
I thought it...before I could type it...you posted it...especially telling when he claims Ford's exhaust brake was better than Ram's...where did that come from...not even in my best Blue KoolAid Days did I ever claim the exhaust brake was better than any ones...it was adequate at best when engaged at 50 mph or less...
...I expect the Blue KoolAid King will be along shortly...
Regards
โFeb-23-2014 06:17 AM
dshizzel wrote:
Realizing that the OP asked about 3-4 year old trucks, I'll put in my .02 anyway. As seen in my sig, I had a 99 QC 2500 Cummins long bed. About 5 years in, maybe 40,000 miles, my fuel lifters had gone out, forcing my injectors to take up the slack and then they went out. Forgive me if my terminology is muddled as this was some years ago and I'm not a mechanic. This required about $3k of work to resolve. I am not handy with a wrench, so had to use a diesel repair shop.
The 2500 2wd with .410 gears did a credible job of pulling our 5'ers though mountain driving often required me to go to 3rd gear. When pulling the 27' Forest River, it wasn't bad, but the 31' Sunnybrook was a lot heavier and often I wished that I'd had more power. The 8' bed was roomy, and I used the room, mostly for stuff that I didn't have time or room for in the 5'er's storage.
I would imagine that, since the QC isn't available anymore in the RAM that a CC with 8' box would be quite a beast, but it is what it is.
Personally, I don't care about the storage lost by going with a 6' bed, but I would like to know what hitching/unhitching, and pulling differences, if any, are to be had with a 6' vs. 8'.
It is also my plan to buy a 2-3 year old TV in 2016 when I retire, so I'm deeply interested in this thread.
Thanks!
DShizzel
โFeb-23-2014 06:08 AM
โFeb-23-2014 04:29 AM
โFeb-22-2014 04:26 PM
