joerg68
Dec 09, 2017Nomad III
Is the camper connected to shore power during these episodes? In that case the sound would probably be the 60Hz AC frequency, and could come from the transformer or any other part that has 120V. That knowledge still won't help you much ... could be a loose connection or an ageing part.
If you look into it - do not poke around behind the control panel under shore power or with the battery connected unless you understand what you are doing.
44,030 PostsLatest Activity: Jan 20, 2025
