wannabegone's avatar
wannabegone
Calling Solar Gurus
It's time to pull the trigger and install solar on our 1181. I'm planning to order within the next month to be ready for a trip near the end of summer. The TC is pre wired for solar. I've decided to wire in series, use a mppt controler and use the existing pre wiring. Here is my list, what more do I need.
Blue Sky Energy's Solar Boost 3000i solar charge controller
2 RENOGY 100 Watt 100w Polycrystalline Photovoltaic PV Solar Panel.
RENOGY Two Pair of 10ft. Adaptor Kit Solar Cable PV with Mc4 Female and Male Connectors AWG 10
2 Sets of Renogy Solar Panel Mounting Z Bracket Set of 4
CES 2 Pin Quick Disconnect Wire Harness SAE Connector Bullet Lead Cable (10 AWG)
1 ATC/ATO Water-resistant Fuse Holder - 10 AWG
Other than decor and time what else needs to be added
