teambeeson's avatar
teambeeson
Camper Battery Under Truck Hood
Hoping you all can help me work through this...
I have my house/camper/aux battery under my pickup hood in the spare bay wired to my starter battery through an isolator. Works awesome. I then run 12 gauge back under the truck and hook into my 12v camper system.
The battery is not connected to the camper's internal converter at all since my truck is in charge of... charging, but all my internal camper 12v- is connected to the negative of the battery directly with a wire spinner. All my 12v+ internals are wire spun together also. It works, but...
What I'm seeing is massive voltage drop when using my water pump/furnace. Furnace sail switch won't even trip. Voltmeter shows down to ~9v when the water pump is finalizing it's pressurization. Yoikes. I have a couple theories...
1. 30yr old wiring/massive resistance internally in the camper? Sure looks okay to me, but I'm not seeing the guts.
2. Too many grounds?? I have the ground/- wire from the battery mixed in with camper frame ground wires... is that bad? I can't see why really, but there is that.
Can't I just get a negative bus bar fuse block mounted in the camper and connect the aux battery from under the hood right to that and then right into my 12v circuits? Would I then even need a camper ground at all?
3. 12 gauge too small for the 16' run from under the hood to the back of the camper? I've pumped a lot of amps through that kinda distance before so I don't think that's it, but maybe.
Thoughts? Those are the only three things I can think of. Gonna start testing stuff. I NEED my furnace sail switch to throw or the main burner doesn't ignite and we've been camping to 20 degrees at night already... in July haha.
