karl1948's avatar
karl1948
Camper weight
I am desperately trying to find the weight for a 1998 Northland 950 Koala TC. Would like to put it on my 2001 Chevy 2500 HD. Any thoughts on this?
  • Powerdude wrote:
    Not a 950, but here is an old thread about a Northland 990. That was allegedly only 2675 lbs.
    A 98 has no slide and a wood frame.
    Assuming he's got a long bed truck SRW, he should be fine. Pay attention to the tire ratings.
    Posted By: sukrfish on 12/02/09 04:16pm
    I haul a Northland Polar 990 on my 2004 2500HD Long Bed. 3200-3400 lbs wet for the TC.
    I upgraded the suspension on it after seeing how much sway I had on the drive home from having bought the camper. Airbags, HD shocks, torklift stable loads...cha-ching.
    I wasn't planning on buying a TC when I bought my truck though. I had the truck first and then decided a TC would be a good idea.
    Knowing that you are going to be getting a TC now, even before owning the truck, I would go with a 1 ton. I know I would if I were in your shoes.
    That extra payload might be useful if you decide to tow something like a boat or enclosed trailer.
    Dan
    Wood frames aren't bad, so long as they aren't rotted or waterlogged. Wood is light when dry and heavy when soaked. Same applies to the insulation....
    Old unit, chances are it has issues.
  • Not a 950, but here is an old thread about a Northland 990. That was allegedly only 2675 lbs.
    Dan
  • Manufacturers shy to give weight info, even they are forced to do so by law, but generally 4000 lb campers are those with 11 foot length, while from 9.5 footer you can expect closer to 2500lb.
    More important COG on short camper will spread the weight on both axles, while with longer camper almost all the weight lands on rear axle, meaning no go without dually.
    That if you find factory rating, take it with big grain of salt as all the reports say the weight is always underestimated.
  • Probably 3500-4000 lbs
    Google similar models of the same length. That model was quite common.
