SoundGuy
Nov 10, 2017Explorer
time2roll wrote:
Reese Brakeman can be several different including timed and digital.
Need the actual model number but I think you will soon be looking at a Prodigy P2 or P3.
There are currently 2 Reese Brakeman Controllers and both are timed, not inertia ... unquestionably this is the OP's issue. Remove it and invest in a Tekonsha P2 or P3 and your problem will be solved, assuming the brakes themselves are properly adjusted, which they should be on a trailer this new. If after installing a P2 or P3 you find the brakes are still grabbing at low speeds they may need to be adjusted OR as I did you may have to have a dealer tech chamfer the leading edges of each brake shoe - that will absolutely eliminate any grabbing.
