SWoop2247's avatar
SWoop2247
Carefree electric awning question
Does anyone lubricate the inside rails of their awning?
If so, what do you use?
I seem to have to "help" our awning when we start extending it outward.
Is this normal?
Thanks in advance.
Steve
  • IB853347201 wrote:
    Is this normal?
    Is your battery low? These awnings operate on 12 volts, low voltage will cause them to stall on extension or retraction.
    Definitely not low.
  • There is a cam type helper for metal wrapped awnings- it goes around the awning tube, and kicks it out as it rotates.
  • I use slide-out lube for all the hinged and sliding parts. I also use the slide-out lube on the gas cylinder if so equipped.
    Is this normal?
  • Mine is a Dometic, but similar, and I use either silicone spray for lube, or WD40 to clean the move able joints. If yours is having a binding issue, between mounting brackets and arms, you may be able to push the whole assembly (while extended) in the direction needed, to relieve the bind. I had to do this once, after the wind had pushed it out of alignment.
    The electric motors on these awnings do not have much torque/power.
    Jerry
  • Mine was squeaking a bit. Hit it with some silicone spray. All’s quiet now.
