โAug-22-2012 06:02 PM
โJul-24-2013 10:34 PM
Keysman wrote:Good work on the underbelly!
Well, I went with the West System and am very impressed with the result. I used the slow curing hardener and had plenty of time to spread the epoxy with a 7" roller with a 1/8" foam roller recommended by the seller. Was about $156.00 for gallon of resin, quart of hardener, throw away brush and the foam roller. Went on really well and am satisfied with the product so far.
However, after using goggles, a respirator, long sleeve shirt and chemical resistant gloves I got an extreme allergic reaction from the epoxy. Hands, face, arms legs and private parts. Really nasty. Went to the doctor for a steroid shot on day 2. After five days still waiting for it to clear up. So be careful with this stuff. Only got one coat on but will have to do for now. Will get a semi hazmat suit the next time I use this stuff. Might even have to hire somebody to do it. Thanks for the suggestions.
โJul-24-2013 09:59 PM
โJul-24-2013 08:52 PM
workhardplayharder wrote:
Fiberglass resin cut with denatured alcohol to a very thin mixture. Apply to plywood with a paint brush. The mixture will soak into the wood and the alcohol will evaporate away. Re-apply 2nd and 3rd coats before the resin dries. Practice with some scrap wood to find the right mixture and dry times.
โJul-24-2013 08:43 PM
โAug-30-2012 01:21 PM
โAug-23-2012 06:29 AM
โAug-23-2012 05:20 AM
DHCamper wrote:
West System is the Gold standard for what you need: West System
โAug-23-2012 05:15 AM
โAug-23-2012 04:21 AM
โAug-22-2012 06:45 PM
โAug-22-2012 06:28 PM
โAug-22-2012 06:20 PM
โAug-22-2012 06:18 PM
