bandit86's avatar
bandit86
exposed plywood on bottom?
How many pounds is the loading ramp rated for? It took a 2700 pound Kubota bx25d loader backhoe backing in...
Needs a few more inches ground clearance. Can the axles be flipped, or will that weaken the spring?
In the wheel well area under fender I see exposed plywood, is that normal? Isn't it going to absorb water if caught in the rain? Or is that necessary for any moisture in the walls to seep out?
here is the wheel well pic
