Jun-22-2015 03:07 PM
Aug-29-2015 07:56 PM
Aug-29-2015 07:10 PM
Aug-29-2015 07:50 AM
trailgranny50 wrote:
Our 9200 will freeze icicles on your nose in 100°+ heat in our poorly insulated 25 year old camper as well. When it's humid we always run it on high to prevent it cycling the compressor too much per tech recommendation then low at night if it stays miserable hot.
Aug-28-2015 04:01 PM
Our 9200 will freeze icicles on your nose in 100°+ heat in our poorly insulated 25 year old camper as well. When it's humid we always run it on high to prevent it cycling the compressor too much per tech recommendation then low at night if it stays miserable hot. Have three small dogs and one fat lady that really appreciate the cool. Hubby just uses and extra blanket. If we're on shore power we've paid for the electricity so we use it. A bit more frugal on the generator but have extended run tank too.
Aug-28-2015 03:48 PM
Aug-28-2015 07:31 AM
Aug-03-2015 07:41 PM
Testudo wrote:
Geeze ! Like many posters imply, I think there is something wrong with your unit. Has the refrigerant level been checked ?
We have a circa 2006 Polar Cub 9200 in an OUTFITTER Caribou (that's a pop-top truck camper with weblon soft walls) and that puppy freezes the beecheezers out of us - - even in the hot and humid Florida Keys. I just can't recall a situation where that air conditioner failed to cool us. Typically we turn it on for a half hour or so and then "coast" for an hour.
Frankly, the only reason that truck campers get bigger units is economies of scale. When you're building campers it is more economical to stock and install a one-size-fits-all air conditioner. I think _most_ truck campers would be better off with a 9200-ish BTU air conditioner (...of course, it has to be in good working order). Builders really aren't doing anyone a favor by installing 15000 BTU units. When you think about it, 9200 BTUs would be overkill in a 120 square foot room in your house. Some truck campers are better insulated than others but if a 9200 can handle our soft walls, it can cool your hardwalled space.
Aug-03-2015 07:11 PM
Aug-03-2015 02:24 PM
Jul-08-2015 10:43 PM
Jul-08-2015 05:30 PM
anutami wrote:I have a lance with a 13,500 easy start and my honda 2000 runs it just fine.adambeck7 wrote:
we're very happy w/ our polar cub 9200 in our eagle cap 960 as well. used it up to 107 degree weather just last week and it got it down to low 70's in no time.
Are you sure your unit is the 9,000btu?
I thought eagle cap was putting the 13,500btu unit..,
(And it is a lie the 13.5 btu will run off a honda 2000 generator)
From TCM. Clicky
TCM: Eagle Cap is changing to low-profile 13,500 BTU air conditioners for 2015. Will the new air conditioners run off a portable 2,000 watt generator like a Honda EU2000i?
Greg: Yes, they will, although they will not run on a portable 2,000 watt generator at high elevations. This is another customer driven request that we have heard. The lower profile air conditioners are more money, but we can order in volume so the price comes down.
2015-Eagle-Cap-Low-Profile-AC
Above: The Coleman Mach 8, a 13,500 BTU high-efficiency low profile air conditioner
TCM: What air conditioner are you using?
Greg: It’s a Coleman Mach 8 which is a 13,500 BTU high-efficiency air conditioner. You gain more BTUs and it draws less power. Plus, our campers are well insulated, further increasing efficiency. Low profile is the bigger request, especially on the taller 1160 and 1165 models.
Jul-07-2015 10:17 PM
okan-star wrote:
Here`s an easy list of Colman - Airxcel products made now
Note the ones checked 'power saver '
Click the model # at the right and you can click the spec = data sheet to see the info
Note the 13k power saver models , they draw 10 amps and 1320 watts at desert conditions , easily ran off a Honda 2000
I have the 11k model and it cools my older Lance great , 9.5 amps on high @ desert 1260 watts
Jul-07-2015 08:36 PM
Jul-07-2015 04:45 PM
