converter/charger
kansanforlife
Morning. I have lost my fridge, furnace.stove fan/light. In front of magnetek converter is a fuse board with 6 15amp fuses with no power to them. I do have 12volts to the lights. could this be the converter?
21 REPLIES 21
kansanforlife
there is nothi9ng to the fuses , no 120 no 12v
kansanforlife
Its a 1992 jayco 265fs with a magnetek 942-2 converter.With no electric the ceiling lights will work off of battery. the battery has not been changed.
westend
Have you replaced the battery recently? Is it possible that the battery connections have been reversed?
'03 F-250 4x4 CC
bid_time
Nomad II
Nomad II
Are the six fuses with no power to them on the 120 volt side or the 12 volt side?
enblethen
Look closely at the fuse panel behind the small metal plate adjacent to the 120 volt circuit breakers. There could be two main fuses. Test the fuses with a test lamp or meter, don't trust just looking at them.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
dave17352
You mean you lost just the two light bulbs? If so probably one fuse or they burned out.
NOW 2017 Leprechaun 260ds
2005 Forrest River Cardinal 29rkle FW
1998 Lance 980 11'3" TC
2017 CHEVY 3500 SRW 6.0
B@W turnover ball @ companion Hitch
Honda eu3000 generator mounted on cargo rack
Crestliner 1850 Fish Ski boat mostly fishing now!
CA_Traveler
It's possible but generally all 12V items will work on either the battery or charger. So look for fuse/wiring issues.
It can be helpful if you post model etc for the rig and the charger.
2014 Grand Cherokee Overland
Bob
