May-12-2017 10:54 AM
May-14-2017 06:42 AM
May-13-2017 06:45 PM
May-13-2017 06:42 PM
quarky wrote:
in a nutshell to the expert... what is the standard/code reference for an outside kitchen, add the outside shower while yet at it. I'm at the class action point!
May-13-2017 06:32 PM
May-13-2017 06:19 PM
quarky wrote:
so since this unit is certified according to RVIA ref plumbing nfpa 1192 this does not seem acceptable.
" 7.2.1.2
The waste outlet of all plumbing fixtures, other than toilets, shall be equipped with a drain fitting that provides an unobstructed waterway."
May-13-2017 05:39 PM
May-13-2017 05:35 PM
Lantley wrote:
None of the first generation outdoors sinks drain into the grey tanks some have made various mods to address the situation. Some of the current newer units are now draining directly to the CG sewer via the RV sewer connection. They still do not drain into a grey tank but if you are on a site with a sewer this is a viable solution.
The issue is very basic the sink drain is lower than the grey tank. Water does not flow uphill. You can devise your own mod or use a 5 gallon bucket beneath the drain.
At this point the outdoor sink drain is a well known issue. I imagine 75% of them do not have drains . While the newer units are starting to have a provision for connecting directly to the sewer.
May-13-2017 05:34 PM
May-12-2017 03:51 PM
May-12-2017 02:15 PM
May-12-2017 02:04 PM
May-12-2017 02:03 PM
quarky wrote:
far as pop ups.. that's why they arnt invited/allowed to most parks these days
May-12-2017 01:59 PM
May-12-2017 01:53 PM
