Glacierman's avatar
Glacierman
Delamination Kit"s
Hi! Like to know if any one has used or knows about these delamination kit"s to use on small spots? I have a spot on slide would like to fix, they sound good but would like to have feed back from those that have used this product.
Thanks
  • Ok, so here's the deal. I finished using the delamination kit. I am happy with kit, but my fiberglass skills are lacking. I would like to apologize in advance for not taking pictures of the process.
    I had a long vertical crack in the fiberglass that let water in which led to the delamination. When pulling the fiberglass away, I noticed that the wood sheathing below it had resembled a washboard. I was going to need access to both side of the sheathing, so I cut slits into it so that could inject the resin into it later.
    Before cracking open the kit, I did a mock-up of the clamping so that I would have my act together by the time that I was done applying the resin.
    I got a piece of plywood that was the length and width of the repair area. I applied pressure onto the plywood at three different spots using three different methods.
    For the top, I rested a plank against the top at a 45-degree angle. Since the plank isn't heavy enough to apply pressure, I used a racket strap to pulled the middle of the plank towards the motorhome. The other end was hooked down under to the frame.
    For the middle part of the plywood, I used the two open windows that flanked each side of the repair. I placed a 2x4 across the plywood and used c-clamps through each window opening to apply pressure.
    For the bottom part, I backed my lawn tractor to push a plank into the bottom of the plywood.
    I pulled it all apart and then started my project. The kit was easygoing to use. I pulled out the measuring cup from the box, added 3 parts Resin and 1 part hardener. You now have 45 minutes to finish the job.
    I poured it into the syringe and injected into the slits that I cut into the wood sheathing. I then began spreading it between the fiberglass and the wood sheathing. That took several syringes of resin mix. The kit had more that enough. In fact I have plenty left over for next time.
    Time to apply pressure. I didn't want my plywood to come into contact with the oozing resin mix. I hung three trash bags over the repair, then placed my plywood sheet. Since I already had rehearsed this, I quickly applied pressure to the plywood so as the crush the fiberglass, wood sheathing together with the resin. I used the 2x4s, clamps in the windows, planks, frame-mounted ratchet straps and the lawn tractor to push it all together.
    24 hours later it was time to see the results.
    I remove the clamping, the plywood and the trash bags. I saw there was a lot of resin that had oozed and hardened. A few minutes with a razor blade and a sander had the mess removed.
    I have taken pictures at this point. The resin did its job, but I wished that I could have pushed the pieces together a little better.
    Good enough for a 22-year old motorhome I guess. The important part is that I had abated the damage.
  • ksbowman wrote:
    Bob, Please give us a full review.
    X2
    The web page could have done a better job of informing how it works and maybe showing a test case all without giving away any trade secrets.
  • Bob, Please give us a full review. I have a small spot that few others notice but, my eyes go to it every time I walk by. If this works for you I'll have to try it. The only part that worries me is if the holes you have to drill are noticeable after filling. I hate for the fix to be more noticeable than the delam.
  • I just got this kit in the mail today. I am going to tackle it tomorrow. Wish me luck.
  • Thanks here tis COMPOSET PRODUCTS L.L.C. Delamination Repair /// Composite Repair /// Wood Repair
    Fix Delamination and Re-Bond Fiberglass - Safe on Styrofoam.
    Cost Effective Way to Attack Delamination!
    Kit includes materials and tools for use in delamination repair, including a special SLV vehicle-grade, low-viscosity, high-strength epoxy that bonds many disimilar materials without damaging foam insulation. Also included is a fast-curing epoxy for sealing and bonding prior to application of the SLV epoxy.
    Detailed instructions included. This kit suitable for the skilled Do It Yourselfer, as well as shop use.
