Sep-05-2020 05:07 PM
Sep-08-2020 05:02 PM
NErunner wrote:Bobbo wrote:NErunner wrote:
As for the battery, it has a date of May 2020 stamped on it, so when I bought the camper it was already 3 months old, probably standard? Anyway, I wonder if I should contact the dealer and complain that it's been draining all the time and try to get a new one using the warranty?
Batteries are usually excluded from warranty. They are considered consumables. Even if the warranty covers it, I doubt that they will replace it if it still tests as good, just because you ran it down. You would need to prove it was because of another manufacturer's defect that it was drained.NErunner wrote:
Also there's a red light right at the front of the trailer frame just behind where the battery housing is located, it's always on when I have the power connected, anybody has any idea of what it indicates?
We need to see where the light is. My TT has a red light on the power cord that tells me if I have power from the pedestal.
Thanks, I'll see if I can take a picture of the red light and post here later.
Sep-08-2020 04:52 PM
campigloo wrote:
My trailer battery is not connected to the house charger so I spent 15 bucks at academy for a littlesolar trickle charger. It works great as long as you can get sun on it. It store it in the propane tank storage cover and it’s always connected to the battery.
Sep-08-2020 01:28 PM
Sep-08-2020 11:27 AM
Sep-08-2020 11:12 AM
spoon059 wrote:
Every 2-3 weeks you should be fine. I never drain from the water heater itself, because its easy to foul the threads on the nylon nut.
Are you Arlington, VA or TX?
Sep-07-2020 10:45 PM
wnjj wrote:
I would not suggest doing either of those unless you have a guaranteed way to remember it's disconnected.
Sep-07-2020 06:40 PM
Sep-07-2020 03:56 PM
Sep-07-2020 01:45 PM
spoon059 wrote:
I'd recommend draining your water heater between trips, especially if you are going longer time periods between trips. I don't drain at the water heater, I simply open my low point drains and "burp" the water heater at the pressure bypass switch. It helps keep the pressure bypass switch from junking up with sediment/corrosion.
I open the low points and open the faucets in the bathroom to break the vacuum. All that water drains out the low point on the drive home. 8 years ago we got water from a campground that was likely from a well. Wife got really sick while pregnant and we took the summer off from camping. That water sat stagnant all summer long and stunk to high heaven when we finally got back to camping that fall. Took a couple flushes with bleach and baking powder to get that sulfur stink out of the hot water tank.
Sep-07-2020 10:50 AM
Sep-07-2020 09:55 AM
Sep-06-2020 04:44 PM
Sep-06-2020 12:40 PM
Sep-06-2020 10:33 AM
Sep-06-2020 08:08 AM
