Diesel draw
Andymon
Anyone know how much the draw is when you have a diesel plugged into 110v when it's cold?
2008 Springdale 266RLS
1999 F250 7.3
Medford, Oregon
14 REPLIES 14
Moose10
My '01.5 CTD block heater is 800W, plus I have 2 150W oil pan pads and a Napa trickle charger. Never felt the need to put anything on the NV5600 even at 50 below. Anyway, at those temps nothing runs smooth for a while.
2001.5 Ram 3500 4x4 QC Sport ETH/DEE
on Vision Hauler 19.5's
'06 Arctic Fox 1150
'09 Nissan Murano S
'14 Ford F-150 FX4
'03 Polaris 700RMK VE, MBRP can
'04 Polaris 600RMK VE
'04 & '05 Suzuki Eiger 400's
C_Schomer
My old NTC was 750W. My 97 CTD was ~300W. I don't know what my 03 has. Craig
dmax_83
750w is what the block heater on my duramax draws.
1998 Jayco Eagle 302FK (Honda EU3000is)
2016 GMC Sierra Denali 3500HD 4x4 Duramax/Allison
2003 Honda Aquatrax F-12X Turbo
4x4ord
My 6.7 Ford doesn't draw much. I think I plugged it in only once in three years.
2023 F350 SRW Platinum short box 4x4.
B&W Companion
2008 Citation Platinum XL 34.5
RinconVTR
Every RV'er and Home owners needs one of these:
Kill-A-Watt
lenr
2011+ Ford 6.7 is 1000 watts, 8.3 amps at 120 volts (meter measurements agree). Owners manual says engine temperature stabilizes at 3 hours so I have a timer set for 3 hours before leaving for work.
ScottG
They draw 700 to 750 watts.
Even the big rigs dont draw 1500.
jus2shy
The manual for my truck states 6 or 7 amps of power draw for my motor's block heater. I have it on a timer, so 3 hours before work it's pre-heating the engine block on my truck. By the time I go to start it, it's roughly 100 degrees in the cylinder head in an ambient temp of 14 to 20 degrees farenheit.
E'Aho L'ua
2013 RAM 3500 Crew Cab 4x4 SRW |Cummins @ 370/800| 68RFE| 3.42 gears
Currently Rig-less (still shopping and biding my time)
K_Charles
I believe the 7.3 Powersmoke came with a 1500w block heater.
boogie_4wheel
They fall in to the neighborhood of 750W.
2005 2500 Cummins/48RE/3.73, QCLB, 4wd, BigHorn, Edge Juice w/ CTS + Turbo Timer,Transgo Shift Kit ISSPro Oil and LP pressure gauges, GDP 20/2 filters, Custom Diesel Steering Box Brace
'10 Forest River Shockwave Toy Hauler 21'
Honda EU3000I Genny
JamesBr
If you mean the block heater for a 7.3 ford diesel? I have seen between 6-8 amps drawn depending on the extension cord and voltage at the supply side. I am plugging in at a campground I try to home run directly to the pedastal rather then through the camper.
2006 Ford F350 6.0
2014 Primetime Sanibel 3600
Enough other vehicles to not bother listing.
Previous RV: 2001 Monaco Knight
powderman426
gmcsmoke wrote:
1.21 jigawatts
http://www.dieselplace.com/forum/63-gm-diesel-engines/20-6-2l-diesel-engine/540818-whos-good-math-co...
That must be why I bought the flux capacitor.
Ron & Charlotte
WD8CBT since 1976
32' Gulfstream Ameri-Camp & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
2oldman
About 1200w
