- moresmokeExplorerJust about every sleeper cab semi on the road today has a diesel fired heater to keep the “house” warm in the winter.
- CavemanCharlieExplorer III
GordonThree wrote:
Speaking from a TT point of view, where's the diesel "tank" go? My trailer doesn't have any diesel appliances, and my truck runs on gasoline.
The come with a small fuel tank and because the fuel is supplied to the heater by a pump you can mount the tank anywhere. One video I saw had the tank mounted between the spare tire and the back of the camper. - CavemanCharlieExplorer IIIAfter watching a few more videos they look like a good idea. I'm not sure if I will do it but, it's sure tempting.
- DakzukiExplorer II
GordonThree wrote:
CavemanCharlie wrote:
Humm, I think I'll check it out. My small TT doesn't need a forced air furnace and then darned thing just kills my batteries. I've been looking for something safe that doesn't use much, if any, power.
I wonder how safe they are ?
I'd be worried about an oil leak. I suppose the entire unit could live outside with only the heat output ducted in?
Are they variable output? That's my main complaint about the Suburban it's either max power or nothing. Gets uncomfortable on days that are not super cold.
A diesel leak is a lot less to worry about than propane. - BarneySExplorer III
They make gasoline versions also.
Barney - GordonThreeExplorerSpeaking from a TT point of view, where's the diesel "tank" go? My trailer doesn't have any diesel appliances, and my truck runs on gasoline.
Big Katuna wrote:
Properly plumbed, perfectly safe.
Meanwhile we drive 70 mph with 50 gallons of explosive fuel protected by a paper thin steel tank.
I watched a few videos on it and they seem safe enough to me. The videos are all from Australia though. I haven't found a video made in the USA yet.
I wonder how much currant they really draw while in use ? Most of the videos say 5 amp at start up but, not how much they use while in operation.
They are designed to be mounted on the floor with the exhaust going down through the floor. I wonder if a person could mount one of them a little bit up off of the floor and then route the exhaust out the side of the camper ?
I'd hate to have to cut the liner on the bottom of my TT and there is insulation above that liner too that would be in the way if the unit was floor mounted. - Big_KatunaExplorer IIProperly plumbed, perfectly safe.
Meanwhile we drive 70 mph with 50 gallons of explosive fuel protected by a paper thin steel tank. - GordonThreeExplorer
Are they variable output? That's my main complaint about the Suburban it's either max power or nothing. Gets uncomfortable on days that are not super cold. - CavemanCharlieExplorer IIIHumm, I think I'll check it out. My small TT doesn't need a forced air furnace and then darned thing just kills my batteries. I've been looking for something safe that doesn't use much, if any, power.
About Travel Trailer Group
44,052 PostsLatest Activity: Oct 14, 2025
