woodrow
Dec 21, 2008Explorer
Ford F-Series Super Duty, 2-valve SOHC, 310 hp (231 kW) and 425 lb·ft (576 N·m) ratings for 2000 and later model years
The LLY (internally called the 8GF1) (engine code "2") is a 6.6 L (6599 cc, 403 cu in) turbocharged engine which debuted in 2004 and continued until the end of 2005. It is a 32-valve design with high-pressure common-rail direct injection and aluminum cylinder heads. Output is 310 hp (231 kW) at 3100 rpm and 605 lb·ft (820 N·m) at 1800 rpm.
Can you add ACE!...605...425 a classic gasser post! another example of a non tower on the tow vehicle forum.. thats ok ace..if I only drove up and down the 5 i would have a gasser also...not! I-5 is like a mole hill...you probably havent unleashed the 2 ponies of extra hp out of that 10 cylinder pig. One question, how come I can make 360HP and 650 FTLB's of TQ with 8 cyl.(thats torque by the way) and you make what seems to be a Honda Accords TQ value, I mean the ford escort sorry...too much credit.Move on and realize that your V10 is the old school way of towing efficiently...
44,029 PostsLatest Activity: Jan 13, 2025
