bob213's avatar
bob213
Dinette Cushion Replacement
Plan to purchase new cushion foam from here:
Upholstery foam
They offer several types.
1. HD36 HQ- 2.8lb/ft3 density w/ 35#ILD
2.Lux Foam HQ- 2.8lb./ft3 density with 50#ILD
3. HD36 Reg.- 2.0 lb./ft3 density w/ 35# ILD
4. Lux Foam Reg.- 2.0 lb./ft3 density with 50#ILD
Has anyone replaced theirs? Which foam do you recommend? I'm 200 lbs. and squash the cushion that came with the TT till its flat.
Any suggestions would be appreciated.
  • I do some upholstery work and use this company, that is local. They will cut-to-spec and ship, too.
    Sunshine Foam
    If nothing else, you can price compare / match with your site.
    Cut to spec foam quote
    They seem to have lost their density FAQ in their web site re-do, but here is another one:
    http://www.carrscorner.com/foam.php
    If you decide to buy a slab and cut yourself, use an electric carving knife to cut the shape.
  • I bought foam at Rockford supply. Their prices are about half of what you will be paying at the Foam Factory.
    You want the densest foam you can afford.
  • My cushions collapse under my 240 lbs, too. My solution was to add thick 1" kneeling garden pads from Lowes/Home Depot (I've forgotten which one) under the existing foam so that my fanny never settles down to the wood platform. Cheaper than new high density foam and remains comfortable; original soft foam on top and dense kneeling pad below. Just unzip the cushion and insert. I wish my sofa cushions had zippers, too.
  • Thanks Wayne. I have a couple of those. I might try that before investing in new foam. bhh and westend...still considering new foam. Thanks for the links.
  • Wayne's answer is a good one. Also, you can go to the camping/back packing section of many stores and buy closed cell foam pads that are used under sleeping bags. Very cheap and often will do a couple of cushions for less than $10. Usually not as thick as the kneeling pads.
  • I would respectfully disagree with that. You can get foam that's too dense to be comfortable.
    Isn't that sort of like saying, "You want the firmest mattress you can afford?"
  • I replaced mine with a very firm foam, don't remember the rating, but it is much better. I also did the piece of junk jacknife sofa with the same stuff. Remember that a mattress supports the whole body, but seating only supports your bony butt. There is a company near me, in PA, that builds foam furniture and they will cut and install foam for free with purchase.
